Results 1 to 9 of 9
Thread: Tubbing 180sx??
    May 2010
    Default Tubbing 180sx??
    Hey Lads,
    As above i have started tubbing the front wheel wells of my 180.
    Just wondering is there any need to tub the rear of the wheel well,
    ie;between the bulkhead and the shock housing
    I will be running 18" x 10.5j wheels offset -13 up front ..As low as i can...
    Also as much lock as i can...
    Any help and info would be great thanks.
    Dec 2009
    Just finished tubbing my front last weekend....! No need to tub the rear...! Either flare the arches of if your running 1/4s cut the arch and fold it back and weld it...!
    No need to tub fronts either unless your running massive lock...!
    I think he means the rear part of the front arches.no need for back part afaik.
    May 2010
    Quote Originally Posted by Hachihead View Post
    Exactly Lad..Was on dw lookin up threads,some lads say its a must some lads say no so was just wonderin cud anyone on here clear it up....
    Galway
    for wheels that wide wit a low offset up front an wantin to run loads of lock you mite as well tub the back half of the arch to be on the safe side....it'd be a sickener to jus do the front half then drive it an the wheels be scrubbin the shit outta the back an it'll take feck all extra metal to do it anyway
    Fit a wheel on after the front is done and do a test on it.
    May 2010
    Quote Originally Posted by way2fastforu View Post
    Was thinking the same myself..would be bit of a bitch to have it scrubbin when its all back together
    May 2010
    I would,its just car is a bare shell at min and doing all welding/cutting with engine out is alot easier.to determine ride height and lock etc would need engine etc in to have the weight on it and I dont want the hassle of putting it back together until its painted and in the final fit stage.
    Galway
    ya might as well tub the back half then to be on the safe side if the shell is bare man
