Results 1 to 10 of 11
Thread: Engine Bay
    im in the process of doing this at the min, have stripped everything out of the bay, meaning all wiring, fuses, battery, expansion tank, etc etc
    basically all i will be left with is the engine, brake master and clutch master, and wiper motor, ive sealed up all holes in bulk head and am now at the stage of rewiring. for that im basically putting all looms and fuse boxes inside the car behind the dash and then just running the wires for the lights and fan up under the front wings so its all hidden, then running the wires to the engine from a new hole i made beside the clutch peddle and heater box, wires come out at intake side behind the manafold so again all hidden
    Low and Slow
    Quote Originally Posted by chrisb View Post
    That sounds interesting, have you got any pics you could post up?
    I've taken out the air-con and a few other bits on mine but i'd like to do a proper job on it.
    i have just havent had the time to put anything together for up loading, il prob put up a project topic when its finished showing the different stages
    its supprising how much stuff is actually in the bay that doesnt need to be
    to make life easy its def worth taking out the dash to do it btw
