Just a few quick questions
I was looking at the Regs on the PD website, and i want to clear a few things up if anyone can help;
It says you need a min of a 7 point or better roll cage. I understand where a 6 point connects to the body, but what is the 7th point? I currently have a half cage and if the pipe thickness meets the requirements i want to just add to the existing cage.
Do you need a fixed rear diagonal or will a bolt in one do?
Is there just the two competitions; Amateur/Pro?
Where do people generally put the Cut off switches on the cars (i've an R32)
And finally, do cars have to have bonnet pins or am i reading that wrong?
On a differant note, does anyone know if anyone else plans on running any drift events other than PD in ireland next year? I've been out of drifting for a long time and am basically starting from scratch again, so am nervous about going out against some of the best drifters in the country (i'm sure you will all agree that even the amateur class in PD is fairly shit hot)
Anyway i think thats all i needAny help appreciated
Cheers
Larry
