Page 217 of 515 FirstFirst ... 117167207215216217218219227267317 ... LastLast
Results 2,161 to 2,170 of 5145
  1. #2161
    di Member podgedun's Avatar
    May 2010
    Carlow
    Quote Originally Posted by Darenm View Post
    yep still looking went to look at this last nite but is as fuf as a badgers hole has plenty of power but had a tip at the front http://cars.donedeal.ie/for-sale/cars/1817558
    I heard that the engine wasnt done very well when it was rebuilt and needs to be mapped again, Heard that from the person who done the engine himself
  2. #2162
    Feb 2011
    Meath
    Put the numbers after the "/cars/" part of the link into the "Search this Thread" function at the top! Chances are they've been talked about before, lots of times
  4. #2164
    Feb 2011
    done that already... no results
  5. #2165
    Meath
    Ah right sorry, that white 180 has had two owners in a couple of weeks just to let you know.
  6. #2166
    [QUOTE=timmyr;329284]anybody know any of these cars? thinking of purchasing soon
    http://cars.donedeal.ie/for-sale/cars/2798516
    Normally I wouldn't say anything but hate when ppl try to mislead others.
    I presume that actual spec is different in key areas unless someone put loads of money into it but can't see it as price remains the same as when it was sold 2-3 months ago
    I owned this car just after it came to Ireland 2-3 years ago and then Hositos had it for 2 years, was great although had its own problems and rust on the bottom chassis. Combination of wide track and suspension setup gave it nice predictable drift. Best handling car I've ever owned. Nice power and good response for a car with std mods.
    We put in a t28bb turbo (not HKS) along with new braided oil feed so double check it
    diff was a std UK spec vlsd but pretty tight (not 2 way), double check
    it had a hardcore cobra bucket seat and 4 point 3" harness (gone now)
    clutch was exedy organic (not a paddle one), presume clutch plate dampers are worn out from clutch kicking so that's why it might feel like a paddle one, be warned
    it's splitting 1 m long flames for no apparent reason on over-run, gear changes etc, some laugh
    passing emissions was quite a task, high miles didn't help. I still have the cat off it.
    all brake calipers were giving problems (seizing quite frequently)
    zorst is not new, it was a 3" japspeed system elbow back, had scrapes from speed bumps etc
    that zorst will NOT pass nct, it's loud as hell. When car was sold it had an apexi manual exhaust valve (butterfly) so it could pass the nct.
    front bumper is past its best, I saw it myself about 7 times off the car to be repaired.
    gearbox was noisy, gears sometimes popping out (fooked) rear seal started leaking after silkolene went into it last summer
    At this stage I suspect that the suspension arms and coilovers are worn out.
    On the positive note would be worth checking if it still has a walbro and H-D stage 1 chip
    The fact is what is it like when it works......
  7. #2167
    Feb 2011
    mite stay clear of that so haha
    anybody have info on the silver 180sx i posted above??
  8. #2168
    MEATH
    Dude there are plenty of good cars on this site for sale, at least 2 r32's that are very fit that i can think of
  9. #2169
    di Member TIMMY495's Avatar
    My house, Wexford
    its not low enough!
    Apr 2010
    galway
    Quote Originally Posted by timmyr View Post
    them over fenders cover alot! car was rear ended and had frontal damage!
