Well first of all i changed the clutch in my s14.
I tought there was something off about the feel of the pedal
You would press the pedal & it would be nothing, nothing, nothing then it would work
So i went under the car and opened the bleed nipple on the slave cly and pumped the pedal a few times to flush the old fluid out of it
then filled the resovior up again & went to pump the pedal and it went down to the ground & would'nt come up on its own (had to pull it up like)
i went about bleeding the clutch away then with someone working the pedal up & down for me and no good. the pedal was still not coming up on its own
Kinda stumped about this, why is the pedal not coming up on it own like?
is the slave cylinder fucked or what
I fitted one of those DW braided clutch lines before i did all this as the old one looked half rotten.
by the way i was using dot 5.1 fluid
Any help is greatly appreciated
