Results 1 to 10 of 34
Thread: help sr20
    Motionsick Media Keli's Avatar
    Gorey, Wexford
    You could've clogged up your fuel filter with all the grime on the end of your tank?
    Quote Originally Posted by Keli View Post
    yeah i must check that..if i run a line straight tru would that work??
    Gorey, Wexford
    Quote Originally Posted by rburns07 View Post
    Best off to just change the filter I'd say but I'm far from an expert!
    yeah prob the best idea alright..thanks keli..
    any other suggestions??thanks in advance!!
    bad fuel??
    did you change the filter and did it work?
    like i say there shitand dirty in the lines
    and the fuel filter
    like you chnaged the plugs, coil pack and it firen
    so then it down to fuel,
    Quote Originally Posted by S14a johno View Post
    bad fuel??
    and the fuel filter
    yeah its firen good..
    didnt change the filter no.
    would i need pro boost or millers its only runnin about 250-260 brake??
