normal black top lad
Team Twenty!
We like to be on full of the rack! SR20 in the front 2way in the back!
did you check main bearings?
i didnt actually, thought the big ends would go first![]()
Team Twenty!
are the pullys all ok??
yep they are as far as i kno,
Team Twenty!
are the cams getting oil in the head or is it definitely from the bottom end?
definetly bottom end knock, could it be oil pump do they knock when f***ed???![]()
Team Twenty!
is the timing chain ok, it could be loose and need replacing.
www.premierperformancecars.co.uk
