Results 1 to 10 of 18
    Keepin it Chaos
    Carlow
    mine doesnt move, but those only move a little to help turning and u dont notice!?
    Dublin
    I never noticed my rear wheels moving like in that clip.
    One of my hicas ball joints was worn so I replaced the whole lot with a Conceptua kit, it done the job and hasn't given any trouble since been fitted.
    di Member lsd32's Avatar
    you will need to remove the hicas if its for drifting,as the hicas with try straighten the back end when you drift.as said the elimation kit is the best job and you will need to remove the pumps and all the pipework and loop it at the front so the fluid is just pumping in a loop.you wont notice it really when driving but when the back end is out it will be fighting against you
    If you think you can,or you think you can't,your probably right!
    www.ryansautomotive.ie
    di Member Shane_s's Avatar
    Ya iv looked into this a good bit with my 4door and the job seems to be those kits but the more I looked into it fitting a non hicas s13 seemed to be just as good an option. And the whole system is removed from the car! I'm sellin my s13subframe & all arms now but only caz I need to.
    Quote Originally Posted by Shane88 View Post
    I've an S13 rear subframe in my 32, so no HICAS to worry about, less weight etc.
    Sig removed - See rules
    I did a bith of research on this last night and i think the best way to go is a s14 subframe with offset solid bushes...!
    Keepin it Chaos
    Carlow
    Quote Originally Posted by lsd32 View Post
    haha mine is still on my car and im drifting with it!
    but the plan is to make drifting the car hard so then when i get a lockout kit and coilovers it will be easier! lol!
