Results 1 to 4 of 4
    Default S14 diff in a R32?
    Is it much work to fit a S14 diff into a R32 subframe if I want to keep my halfshafts? How hard is to change the output flanges on the diff? I know you also have to change the backplate but is there any other work involved?
    di Member Driftma's Avatar
    Dungarvan,Co.Waterford
    just fit the centre out of the s14 diff into the r32 diff, or is it a different ratio your going to?
    Yes it will be a different ratio.
    ah right,as far as i can remember its just a case of changing the backing plate and it'll fit, and the output flanges should just pop out of the diff with a bit of leavering and then pop back in to the new diff
