just after ppl's thoughts on whats the best tyre pressure to have on the fronts and rears in the dry and wet
cheers
daniel
cheers
daniel
I run 25psi in the front and 50 in the back.........maybe 40 in the wet but usually stick at the same pressure!
I ran 25 psi front and 30 psi rear at Nutts yesterday. Poor tyres didn't help but it seemed to be a good combo
Yup..........alot harder to loose traction in the Chaser than it looks!! Its suspension set up is set up for serious traction!! Bon used run 70psi in the back
70? do the tires not absolutely shred themselves with the heat straight away?
What pressure are they when they're hot Chuck? What tyres you running actually? And they're 265s aren't they?
iv heard of a few lads running 60-70psi on the rear
i thought i was badass putting 45psi in my mountain bike tyres :o:rolleyes:
i always had 30 psi all round in the road cam and the trueno i have 30 in the front and 40 in the back
i had 40 psi in my road wheels last time i was in nutts and they delaminated after 1 lap....ONE FECKIN LAP due to the heat! so i ran after, although my old tires that were sitting out in the garden months lasted ages with 30 in them.
I found my car goes better with lower pressure, 22 - 25 in front, 25 - 30 in the back. Then again this depends on conditions and power etc..
i run 25psi front wet and dry and rear is 45psi dry and 25psi wet
yesterday i was running 30 psi on the front and 40 psi on the back.
50psi on the back :D
il take that on board darragh and drop it for the next time i get out
does the higher pressure really make that much difference ye????
ah maybe thats why my wheels wont spin up in 2nd in dry well that and the MASSIVE TURBO LAG
true i can vouch for that,cloud machine:D
i emphasise WHEN LOL:p
ha ha i want to see what it looks on steelies:p
burn em off the hubs :p
You using RSR's chuck?? they mightnt delaminate so quick as there're designed for track use, and getting hot..
I run 30/32 in the front and sometimes 25 in the back to stop them delaminating..
If tires start delaminating let the pressure drop, its amazing how much the psi rises
as soon as ya do a few laps in a driftcar!
