hi ive a gtst skyline r32 and the steering arm bushins are bad.is there any way to lock off all the rear wheel steer and will i still have to replace the bushins??:confused:
Get your hands on either the
Driftworks Hicas Lockout Kit
or
Conceptua Tuning's Bycas Kit
I had the same issue, and went for the conceptua kit. problem solved, and tightened up the back.
have heard great reviews on the driftworks kit also
As above.
The rear steer ball joints are commonly worn an all older skylines and 180's.
Conceptua do replacement balljoints but you'd be as well get the full lockout kit and get rid of the whole hicas system.
I got the DW full hicas ilimination kit, unreal differance!
hicas bar is your only job
You can also replace the rear subframe with one from an s13, this was done with my car before I bought it
i think i need one of those DW kits too..
ok cheers guys ill get the lockout bar and replace the steerin arms.:D
I'v a couple of them ball joint's brand new nissan one's sitting up the shed gathering dust, if ye need em let us know,'our' old liner had a tomei lock out kit wasn't a bad set up either
