anyone breaking a 3l supra 93 model.
I need the plugs that go onto the injectors
Levin 20v plugs are the same afaik but Christy is breakin one
steo84 has one or two to break there
bump is there nobody breaking one of these
id say even if people were breaking a few of them they wouldnt cut the loom as it be usless there after and would be one the first things to sell for a conversion, your best bet is pull out an injector and head to a few scrappys and find your self some oters to match most toyotas are the same anyway
i have a non turbo 2jz loom,if thats what ur after
I have a 2j non turbo loom there aswell
its just the plugs for the injectors im after lads.would ye be willing to snip them off
I'm sure you could get new ones from Toyota? I needed the connectors to plug the loom into the coilpacks and I managed to get the part number on the net and they were only a fiver each. I'll have a look for you, I could do with some myself two of mine aren't in great shape
On another note, I don't mean to hyjack the thread but do wither of the guys have a 2JZ resistor pack for fitting low impedence injectors to a 1JZ??
sorted .lock it up.anyone in the same boat a 93 corolla is the same
