anyone know where a crack shaft sensor is in a sr20det??
the story is my 180 started running lean all of a sudden then i thought it was just went and bought a apexi pfc and put in the 550cc injectors high pressure pump adjustable fuel pressure reg and z32 afm so brought it to get mapped but no joy couldnt be mapped or fault couldnt be found so i brought it home again and put all standard bits back in (injectors afm etc...) but it was still the same. could a idea about and hour ago to plug in our diagnostics and the fault came up as a ''crank shaft sensor or wiring'' so does anyone know whats up with it??
and also forgot to say its only running on one cylinder at the moment
help needed asap please????
