has anyone ever had manifold studs break in the block on an rb? iv tried stud removers but no joy, anyone had this problem? help!:(
Drill and tap baby,Whore of a job
oh and theres 5:(
Oh cock as they say in ffrench
Are you any good with a stick welder, weld the bolt and built it up, then once its out pass the head weld a nut over it, and slowly turn it out with a spanner. The weld will only build up on the stud as the head is aluminum but you can only weld for a short amount of time at a time.
You build it up by welding for only a few seconds at a time, so you don't heat the head too much. Its common on RB, had to do it to the RB26 + RB25. 26s are worse smaller studs!
I think there is a guide on the net, will have a look
the stud arent flush with the head, there in a good bit
Found a guide on how to do it without welding but not sure if it works too good,
http://skyline.uptomyneckinit.co.uk/skyline/index.html
The welding method does work, and if you are going to do it, be careful. Just weld the centre of the stud, dont fill it completely, and gradually build up the weld. you might have to try it a few times, as the weld might break. And I hope they are all not at the back of the engine next to the bulkhead, as space is tight :-( Best of luck
I have a set of uprated studs here if you needed them.
