One of these wanted please if you have pics that be great
Dont do it man. Youl be taking it off once a week to weld it. I had 1 on my 180 and it broke my heart. Standard cast iron ftw.:D
The fella Jamie180sx on here was to sort me out with one said he had it i said id take it ive been trying to get in touch for a week and a half cant get him anyone know him
dont belive all ya here ted, i have a tubler mani and savage bit of gear, got it off christy and know load other people who have A/M manifolds
just check the welds but it cunt of a job todo and if ya dont have braided lines get them
man trust me you need them, i changed my own manifold and never again, colm dunndrifter tell ya it a cunt todo, If you go with manufactor turbo lines it be a bastarded to get on (line up the bango bolts), braided lines are more flexable so it matter drop in the turbo and mani bolt everyting up and then you braided lines,
ahhh depends what you want shine or not, but belive me the manifold will get bloody hot,
i just have exgust wrap on the EX TEMP Gauge
if you want any i have a roll there
if you want i done a write up on it ill pm it over to ya,
also i mad a heat shield for the turbo silcone hose
very handy
I have a japspeed one on mine its on a few months no cracks yet
Really? Thats very interesting thats what i was asking in the Tech section would i lose torque unless i was going above 380. Well fairplay lads. Whats the best areas to put money into without changing the turbo? Cams be an option?
iam kinda at the same stag as you ted, like i went with mani becasue a wanta a fast spool up with means more speed,
like if ya do the cams you mite as well do the rods too and then ya have to map her,
like i dropn a turbo into her as it my next stop , the internals will hold to over 400
then start worrying boat it, but comes down to what power you want
like i had a standerd mani on and it ok and then i changed it to a tubeler mani and yes it is quicker i feel my self
stabderd mani good to 300 as stevo says,
well what you spec list of the whole car lad, then we can advice you
what brake setup you have lad
I got R33 brakes front and back and have Do Luck powerlines comin tomorrow.
I havent checked the injectors i was going to buy s15 injectors off someone but i was told i wouldnt need them unless i was going above 300. and then i would need a map. If i wanted 280 would i get it without cams injectors turbo and map?
well you could get 550cc injector ( i have 740) and ecu and z32 you be at 296 lad
that what i rember from mine last year
well make sure there not purple, you get away with 550 cc injectors ( yellows)
standerd injector will cut out after 5000 rpm i tink
becasue they not let enough fuel in
Podgge 14 had standerd injectors and it made it to 300
but the injectors wouldnt hold pass 4 5000 rpm
Depending on boost levels,STD injecotrs are ok for around 280-300,but ya would be better off upgrading them if uping the power as u don't want to running over 80% of the injector ideally that is
well to me you next stop is injectors and ecu,
jamie rite too running injectors on 80% never great
ooo 740 will let you run E85 if you ever wanted too bearly do
stiv will sort you with nistune and just keep a eye out for injectors
