Originally Posted by
jamie180sx
the best fan setup we come across after trying lots of different setups is a custom one.what you do is find 2 honda air con fans from sir/type R which ever.then shave the inner side of each fan and weld them,down the middle,then wire them to a switch in the car.ive mine wired together and when i turn on the fans while waiting to line up i find they cool it 2 much nearly and have to turn them off to let it back up.this is the ultimate fan setup and are extremely slim,if you check out my project thread u should see them.also there an savage fit,almost like they were made day one for the job.also a good setup for a sr is nissan vanette 2,3d,they bolt directly on but drain to much battery power.
hope the info helps,any probs or questions just ask,or if probem sorting them let me know
p.s dont mind the shite welding as it was rushed
