RB25, SR Gearboxes & Diff's For Sale and R33 & 300ZX for Breaking
R33 for Breaking - Everything there except Engine, Loom, ECU & Gearbox, Prop, Slave.
http://i1362.photobucket.com/albums/...psgkxwdoa2.jpg
- RB25 Gearbox (Perfect Condition. Slave, Gear Lever & Prop also available) - €500
- Front 5 Stud Hub Bearing's (Perfect) - €40 each
- Front Lower Control Arm's, same as S14/R32 (Balljoint & Bush Perfect) - €40 each
- Front Tension Rod's (Bushes Perfect) - €20 each
- Front Upper Control Arm's (Bushes Perfect) - €20 each
- Brake Master Cylinder - €50
- Clutch Master Cylinder - €40
- Front Bumper (Has small crack's & paint chips) - €40
- Bonnet (Dented but repairable) - €20
- Wings (No dent's or Scrapes) - €20 each
- Headlights (Good condition) - €40 each
- Windscreen (Perfect) - €100
- Rear Glass (All 3 pieces) - €50
- Front Seat's (Good Condition) - €50 for the pair
- Dash (Good Condition) - €40
- Rear Diff 4.1 (Standard LSD is quite tight) - €150 or €200 Welded
- Rear Subframe (Same as S14) - €80
- Rear LCA's (Same as S14/R32) - €40 each
- Rear Toe Arm's - €20 each
- Rear Camber Arm's - €20 each
- Rear Hub Bearings (Same as S14/R32) - €40 each
- Rear Lights - €40 each
- Rear Bumper (Good Condition) - €40
- Rear Spat's (Good Condition) - €20 each
- Standard Exhaust with CAT - €100
- Shocks (All good, will pass NCT) - €20 each
- Air Flow Meter with plug (Good for 350bhp) - €50
- Rear Brake Setup SOLD
- Front Brake Setup SOLD
300ZX for Breaking - Everything there except Gearbox, Prop, Slave & Calipers & Disks.
http://i1362.photobucket.com/albums/...psstofaf70.jpg
- Z32 Air Flow Meter and Plug - €120
- Z32 ECU (This is the ECU needed to run NIStune's with RB25's) - €150 (No offer's, I'll keep it otherwise!)
- Rear End: R220 Diff, Driveshaft's, Rear end of Propshaft and Hub Bearings - €400 or €500 for Complete Rear End
- 6 Puck Aftermarket Clutch, Pressure Plate & Release Bearing (Make unknown but in good condition) - €150
- Front Bumper (Perfect) - €80
- Bonnet (Perfect) - €50
- Wings (No dent's or Scrapes) - €40 each
- Headlights (Good condition) - €60 each
- Rear Hatch with Glass (Perfect) - €100
- Doors (Perfect, complete with Glass) - €40 each
- T-Top Glass Pieces - €40 each
- Shocks (All good, will pass NCT) - €30 each
- Rear Bumper (Perfect) - €50
SR20 Gearboxes X2 (Perfect Condtion) - €200 or nearest offer
Open or Welded Diffs (3.7 & 4.1 available in S13 or S14 Fitment) - €150 each
Delivery available and Card Payment taken over the phone if easier!
Phone: 0876179780 / 01-2015050
