breaking my ps
im only putting this up to see if there is enought interest in breaking it no parts will be removed untill enough interest is shown
body:
spotless registered shell not dent or scratch on it 1800
full origin streamline kit modded front bumper 400
+30mm vented wings 150
+60mm over fenders 150
vented bonnet 250
big big gay wing 250
18x10 et15 5x114 rota grid drifts as new 1000
brakes:
5 stud conversion
r32 gtr front discs and calipers
mazda rx7 rear discs with custom brackets to mount s13 calipers
ksport hydro dw lines stick all above 600
suspension:
front
jic magic coilovers HKS top mounts 250
silk road adjustable track rods and rose jointed ends with extra lock 200
supemeade tension rods 170
nismo front subframe 90
tomei 3 point top strut brace 150
36mm anti roll bar 150
tein front valance to a pillar braces 100
rear
hks hyper maxD coilovers polow ball top mounts 250
cusco upper camber arms 100
cusco lower camber arms 90
cusco toe arms 90
all adjustable and rose jointed
26mm anti roll bar 150
polly bush subframe mounts
fet top strut brace 70
cusco subframe brace 50
arc chassis leg extension (the bit nissan forgot to put on the passanger side of the s13)100
engine:
sr20 det red top 900
acl race main bearings
acl race big end bearings
acl trust washers
555cc sard injectors 350
z32 afm 100
trust filter 50
apexi intake pipe for z32 80
hks acuator 80
silkroad manifold 150
nismo stainless gaskets
stanless screamer elbo 70
veilside 3"down pipe 150
custom decated 3" exhaust system no boxes 250
fmic alloy hard pipes 250
blitz bov 70
nismo r32 gtst engine mounts 100
greddy emanage ecu with boost sensor 200
3 layer alloy rad with electric fan and nismo cap 180
drive:
x2 standerd sr boxs 300each
nismo light weight flywheel 190
nismo solid organic cluch disc 100
nismo pressure plate
nismo 2 way lsd 600
nismo box mount 40
interior:
omp set buckets
3" harneses 350
7 point bolt in cage with door bars 400
some parts pictured here
http://www.driftireland.com/showthread.php?t=1593
has the z32 got a plug????
dibs on it if so:D
will those camber arms fit a 15
@bart ye has harness
@shee the camber arms will not fit an s14 you need ones for an s14/15
any pics of this bad boy (apexi intake pipe for z32 80)?
some pics here lad
remember this will not be broke untill enough interest shown
In that case ill buy your nismo rad cap :p
if its gonna be broke, id be interested in the cusco arms
Interested in the front strutbrace and the chassis leg extension.
the big gay gay gt wing pm me and let us no if u are
be interested in a few bits but dont have a penny till my tax return comes through :(
take a fuel pump an the rear lower camber arms for now
Yo yo gayface,dibs on the rad!!
Dibs on front wings and indicator/parker
is that 350 for the seats and belts if so DIBBS
so is this car for breaking?
If broke id be interested in the rear overfenders...dibs:D..
maybe some more bits..depending on money
no lads im not breaking it there is not enough interest in bits to justify it
Thread closed, let me know if ya want it back open Gem!
Simon
