The woman is looking for a rwd car so I am looking to swap my renault 5 gt turbo and fireblade for any rwd jap car eg. silvia's, 180sx, twincam etc or 4wd gtir pulsar. Any thing considered even damaged or gearbox trouble!! If wanting any details about both let me know!
This is the spec of r5:
Renault 5 gt turbo phase ll 1990
Tungsten grey
engine fully lightened and balanced bottom end
EP race spec cam
Forge twin core alloy intercooler
samco boost pipes
magnecor KV 8 leads
NGK red box racing plugs
F&W carb mods
brand new renault 2000 cst low comp head
Uprated HG Volvr heavy duty clutch
ratchet type chain tensioner
EP copper fuel lines
special stage 2 hybrid with 360 thrust bearing made from minimal lag
bb braided oil feed pipe
sfs turbo oil drain pipe
copper core rad with low temp fan switch Magnes full system
GTT closed loop dump valve
cossie K&N air filter
Mocal 13 row oil cooler with theromostat
Baffled sump modified to fit ph2 oil drain
PMW uprated fuel pump
B&Q/PMT water injection system
Armtech rev limiter with full throttle gear shift
STYLING De-locked and smoothed all round, side repeaters also removed and smoothed
Koni suspension adjustables and lowered 60mm
new wishbones, ball joints and full set of polysport bushes
Green stuff pads
new master cylinder
goodridge braided hoses
brembo discs
15inch TSW blades painted in peugeot graphite grey
gauges
kenwood 6.5inch components upfront and infinity 6x9 in back
standard interior
Fireblade spec:
99 Fireblade 900cc rr
15,075 miles
polished rims
carbon hugger
carbon micron exhaust
double bubble screen
new chain and sprockets
new brake pads
http://i568.photobucket.com/albums/s...a/Image062.jpg
http://i568.photobucket.com/albums/s...age027-1-1.jpg
http://i568.photobucket.com/albums/s...Image012-1.jpg
