Lads have the turbo and non-turbo SR's have different internal's?
Can i just bolt on all the turbo parts / wiring onto a SR20DE engine?
Thanks in advance
Thanks in advance
the de will have higher compression ratio and prob diff pistons and rods, ive not taken one apart so only assuming becuase of the different loads put on each engine
the blocks are the same afaik though
different block inside and the rods are way smaller and different pistons!!! smaller valves in the head!! it would blow in no time!!
As said the internals are different,There is also no take offs on the DE block for the oil and coolant lines to the turbo.
on sr20de:
high comp pistons
no turbo oil/water feed
no oil squirters to the bottom of the piston (for cooling them)
different injectors
I presume valvetrain is different (esp. cams)
clutch/flywheel are smaller
plus some extra bits needed:
CAS
turbo AFM
ignition amplifier (ignitor chip/module)
loom
prob. downpipe/elbow
etc.;)
Thanks lads, that puts dat idea outa me head. Thought as much
hi lads,sorry to hijack...but im driving a s15 sr20de,and just bought a s14 sr20det engine:) im just woundern if some1 could tel me what else i need to do the conversion??and a good mechanic in the west of ireland who would do this??
im in galway.
wats part galway u in lad??
out west spiddal way,u???
ah ur bit far out im in athenry myself....id be able ta do that conversion for ya but im flat out workin on my own yoke but i can give ya a num of a lad that mite do it for not that much....pm me if ya want it
how much u reckon it would set me back?
is their a difference in the s15 spec s gearbox and s14 sr20 det gearbox?????
I think all s15 boxes are 6speed so theres an extra gear in there compaired to the 14's
no the s15 non turbo is 5speed, is it same box as on sr20det turbo engine??thats wht im trying to find out...
I'm fairly certain the Spec S diff & box are the same as the S14a but as far as I know the clutch and flywheel are different
do spec s's have a viscous diff?
Yup, only the R's (& Autech versions) have helical ones....
It'd surprise you ;) If I was any good at drifting I would prove it but I can't drift to save my life :( A lot of fun around mondello all the same though.....
Meego; There's a few threads on S15OC of det'd spec S's, I'm sure you'll find one using the standard box / diff...
edit:
best I could find is Auto spec S to manual DET - none of the others had decent write ups or the links to pictures were no longer valid....
http://forum.s15oc.com/showthread.ph...h-s-drift-ride
