This is up back up for sale. Other priorities
Car was fully remapped only a couple of weeks ago at tdp! (02/11/2012)
Very grippy setup and very competitive car, all it needs is a good driver.
Car and spec[/B]
Engine & Fueling
Running 408bhp and 377 lb/ft @ 1.3 bar mapped on a Nistune board.
Hybrid HKS Gt2535r. Full trim 2871r core with the .64 2535 compressor housing & exhaust housing. Upgraded copper and MLS turbo, mani & D/P gaskets. Built by AET turbos. Have receipt
Sard 550cc injectors
Pink label Rb25 AFM
Malpassi adjustable fuel pressure regulator
Fuel pressure gauge
Frount mount intercooler
52mm Twin core Aluminium radiator
HKS intake and filter
Oil cooler and filter relocation kit
Upgraded stainless valve cover bolt kit
Custom full Exhaust system
Japspeed Engine Damper
Oil catch can
HKS EVC 5 Boost controller
All vacuum lines Samco hosing
20litre fuel cell mounted in boot, boot floor has been removed
Swirl pot
Bosch 044 & 909 fuel pumps
braided lines & aeroquip fittings -(System has connections/ports for another high lift pump, 044 etc for running twin pump setup..)
Suspension & Drivetrain
Coilovers
Tein rear & HKS Hyper-D front
OS Giken triple plate clutch & lightweight flywheel
S13 subframe
Solid aluminium subframe mounts
Polyurethane a/r/b bushes
adjustable rear toe arms
adjustable rear traction arms
adjustable rear camber arms
polyurethane drop links
Tein tension rods
Driftworks front camber arms
Japspeed tie rods
Custom rosejointed tie rod ends(Aurora amt10 high tensile rosejoints) with adjustable bump steer correction 5-30mm
Modified hubs
Modified steering rack
Modified subframe
Driftworks solid steering bush
Red stuff pads
Ultralite 25mm spacers rear
Superforma 20mm spacers front
Rota GTR 18 & 17 x 9.5 et12
Interior & fabrication
Custom 8mm steel window frames
Lightweight polycarbonate window kit
Grp4 fabrications CDS weld in adjustable seat mount kit
Full welded in custom roll cage
Custom fabricated firewall
Custom fuse board and switch panel, push button start
Compbrake Hydraulic handbrake
Brake Bias valve
Sparco rev seat
Sparco six point harness
Sparco deep dish suede steering wheel
Gauges;
Oil temperature
Water temperature
Oil pressure
Boost
Tachometer
Exterior/bodywork
Do luck rear bumper
Driftkits.eu front bumper
Origin side skirts
Origin Drift wing
Dmax roof spoiler
Dmax style overfenders rear
Jun style arches rear
Jun arches front
€7500 ono
0857127526
How it looks now; (projector headlights and indicators fitted since pics)
https://fbcdn-sphotos-h-a.akamaihd.n...00824971_n.jpg
https://fbcdn-sphotos-f-a.akamaihd.n...15528604_n.jpg
https://fbcdn-sphotos-g-a.akamaihd.n...63392043_n.jpg
https://fbcdn-sphotos-e-a.akamaihd.n...47431718_n.jpg
https://fbcdn-sphotos-c-a.akamaihd.n...49243435_n.jpg
Some older pics;
https://fbcdn-sphotos-a.akamaihd.net...28580224_n.jpg
https://fbcdn-sphotos-e-a.akamaihd.n...31777156_n.jpg
https://fbcdn-sphotos-f-a.akamaihd.n...66465215_n.jpg
https://fbcdn-sphotos-h-a.akamaihd.n...62317811_n.jpg
https://fbcdn-sphotos-c-a.akamaihd.n...86360793_n.jpg
