looking for a gtr fuel pump asap let me know whats out there cheers
The daggsy has one for sale on this page about ten threads down
I have a nearly new walbro there Gary, I just bought it from conceptua in the UK, all the fitting bits with it new in the box. I used it for 3 days out in the car before I took it since im fitting a fuel cell, i can guarantee you its spot on. pm me there
Edit: or text me even, i can post it on to you
I have one there lad in mayo 80 collected or can send for extra
have 1 der from carlow
Have one too in for sale thread in clearout parts
Bump again
85 delivered
Can you send me on your details lad cheers
Gary ill give you the walbro for 50 delivered, its practically brand new man and every bit as good in the box with all fittings as new!!!!
Ring me there or give me a text
I have one in it Kyle im changing to a Gtr pump because there ment to be alot better i know the walbro have a short enough life span that's y i want a Gtr pump having a bit off a petrol problem at the minute every time i go around a corner she cuts back on power and won't get petrol
That wouldn't be down to the fuel pump Gary. That would be fuel cut due to starvation of the pump when all the fuel swashes to the opposite side of the tank when cornering. I had the very same problem with my 32 which is why I put the swirl pot in and it solved the problem, never had an issue with it since
I was told the car did it before and they changed the pump and it solved the problem i had the car full off petrol and pulled grand in a straight line but then corners it would cut out so when i pulled in opened the fuel cap and it started gushing out on me checked all lines and was getting petrol so its realy a funny one so was thinking off trying a new fuel pump aswell
It was gushing out the fuel cap when i opened it was that the only way you solved your problem mine sounds more like trapped air because i had a full tank and was still at it
I could be wrong but if you are having fuel cut issues I don't think swapping out a walbro for a gtr pump is going to solve it. I had a gtr pump in mine also before the walbro and either way I still had fuel cut. Yes swirl pot is the solution.
You can get one from Murray Motorsports for €50 and then get a second hand bosch 044
yea maby so lad was just told that tho ? but dont want to put big money into a fuel cell set up and wont have the funds or time before round 2
Ive a GTR & Walbro for sale but they're in UK and im not back over there til next week...
