what ye think of something like this for first car?
http://cars.donedeal.ie/for-sale/cars/3252982
Hydro and a cage would all she'd need maybe few suspension bits and extra lock...
If its ur first track yoke your best getting summit cheaper to slide than that and learn the skills and build your confidence up b4 getting a dear yoke, ur bound to make a few mistakes and you dont want be repairing a good car all the time and the car will just end up destroyed. Unless ur minted and can afford to bash and repair summit nice. just my 2 cents!!
on second thought i think id be best to take your advise.....only thing is its hard to know what to start of with....maybe BMW 325 328 or Altezza some of them are going under a grand least you wouldnt have too much to loose with one of them yokes i suppose..
Ah there's a few s13 an s14's goin for small money now on donedeal. No bother gettin the parts here then if ye need them
s body is what most people start off in plenty of power and will b more that capable than u are at the start s bodys are going cheep these days
boom http://www.driftireland.com/forum/sh...ad.php?t=27491
Great lump of a car to start in: http://www.driftireland.com/forum/sh...ad.php?t=26556
If its any use to you i was always told if i start in an underpowered car it will make me a way better driver ie. na 16 valce cam or somethin like that... I assume its cas u have to be alot more commited
as dan above me said start off in something underpowerd like a 320 itl make you a much much better driver because it teaches you how to push your car as hard as you can
what would a sr20de be like for starting off
Shame ta track her but so easy ta get parts for the s14s.sr20s fairly relable engines.
i had the same problem last year bud and one of the lads convinced me that an s bodied sr20det was the best way to go and i never regretted getting it i'm still only learnin but the cars more than capable for startin out..
I personally started in sierra's, no power and bad lock made it good craic so when i made the jump to the first skyline i had sliding it was really handy in comparrison and had loads of confidence
Buy something that only needs minimal work, parts add up if you buy a cheaper car.
buy a mx5 import and go nuts mate :D
http://cars.donedeal.ie/for-sale/cars/3211684
would leave ya plenty of money to set up as you want, and 2nd hand parts are cheap as chips
what about my car, can be used as it is until u get used to it then tidy it up
http://www.driftireland.com/forum/sh...ad.php?t=27526
Start out in any rwd car your budget suits.!
I have a 32 year old dx corolla standard 1.6 carb engine and still gave it a go the last day at drift fest.
So dont know where lads say a 2litre wouldnt have the go to drift!
Under powered makes you work much harder, but in the long run if you can learn in one you'll become a much better driver as once you hop into a 180 or the likes you'll be flying!
You wouldnt be able to do it the other way aound as easy from a high powered car to a lowwer n/a car as you'd get a serious wake up call!
as has been said, gettin some cheapish that you dont mind if you wreck it.
mx5 1.8 or a 325,323,328 e36 bmw.
