Anyone any long term experience with them? Are they likely to sheer or explode or anything on a daily driven road car?
How cheap?? I'm sure they be grand!!
i cant remember who exactly, but theres been a few threads lately on people spacers being shit and the wheel falling off!
Thatd be mine
I had just bought the car and they were slip on spacers
Got proper bolt on ones now
I had a wheel come off one nite going around a roundabout, its not fun to say th least!! wheel ended up 300 yards up the road!!
like really cheap chinese shit cheap
http://www.ebay.ie/itm/20mm-Wheel-Sp...item43a98a06dc
Yeah I wouldn't really trust the slip on ones anyway unless I had extended studs or something, any idea about the hubcentric ones though?
Oh fun! What happened? Did the whole spacer just break off?
If the specs are what they say they are then they should be grand however i would change the studs! 6061 should be ok!
They're nearly 70 squids posted! not that cheap?
I'm nearly sure if you try east coast alloys they do basically the same thing for less.
Also says on those that the studs are 12x1.5 so unless you have open ended nissan nuts you'd have to get a set. The nuts they give you can only be used to hold your wheel on.
The bolts are only grade 8.8. EU law states a minimum of 10.9 for wheel studs bolts. So if you cause an accident a PSV officer could hold you liable for all damages.
Robbie
i got these, they came with spigot rings etc
http://www.ebay.ie/itm/Ultralite-25m...item4cea00da1d
