Looking more camber on front of my 180sx have coilovers cambered in fully but still not enough heard r33 skyline wishbones give a bit more and 40mm spacers any ideas??
is there 8 treaded holes on the topmount?for moving the camber bolts those adjusted fully give fairly good camber.s14 wishbone give 10mm wider track either side
Il check in morning there apex ones neway
Thanks mate does the s14 ones give more camber than the r33wishbone
Both S14 and R33 lca's give 10mm extra, get them modified if you want more. Or go and buy adjustable lca's and camber arms
take out front coilovers and get the top hole were it bolts to the shock elongated so u can slide the hub in and out get all the camber you need
Why do you need so much camber?
Get a second set of wishbones. Cut a 10/15/20mm(however long you want it really) section out of one set. Cut the other set weld the section back in.
billy (driftescort) will sort ya out with modified lower control arms drop him a pm..he does savage work
Go this link to his build thread, pics of the arms are on page when you click link
http://www.driftireland.com/forum/sh...t=6715&page=11
