Well.......I bought this off Jay & Bob after Punchestown 11. It was a pretty standard car that was stripped out and had the following bits on it;
Bolt in cage, seat, hydro, front mount, fuel pump, Coilovers, a welder and custom turbo back exhaust courtesy of jay and bob. It is a good straight car with a healthy heart!
Here are a few starter pics of how the car sits at the moment
Looking sorry fot itself in the garage
http://img16.imageshack.us/img16/1470/dscf0007fu.jpg
I came a bit too close one too many times :-( big thanks to Gem for sorting it after the third time! The whole quarter was demolished after the last tap of the tyre bales in Mondello and he managed to get it straight again and put the original shape back into it.
http://img560.imageshack.us/img560/5246/dscf0005nd.jpg
http://img705.imageshack.us/img705/9916/dscf0006dc.jpg
Here are a few pictures of the suspension parts that I put into the car back in August....S13 subframe, solid alloy mounts, polybush drop links, adjustable rear toe, camber and traction arms
http://img714.imageshack.us/img714/4498/dscf0008bh.jpg
http://img821.imageshack.us/img821/7359/dscf0010cu.jpg
http://img805.imageshack.us/img805/8181/dscf0011sn.jpg
The inside of the car as it is at the moment
http://img853.imageshack.us/img853/1763/dscf0014gf.jpg
On the way;
Rebuilt HKS 2535 thanks to drift escort (deposit paid tonight, collecting next week)
Uprated Copper Mani to Turbo Gasket & Turbo to Elbow Gasket
Oil Feed & return washer and gasket
Malpassi Adjustable Fuel Pressure Regulator with Adaptor and Gauge
Walbro 255 Pump
New Exhaust Manifold Stud & Nut kit
replacement Hks Filter
New stainless steel bolt and washer kit to replace valve cover grommets and screws with
New upper and lower Injector seals and Sard 550's
Rocker Cover Gaskets
MLS Manifold Gasket
Pink label RB25 afm
Next on the list
Weld in cage
Alloy rad
tein rods and ends
tension rods
modified hubs or have been thinking I might go for driftworks knuckles too
camber arms front
modified S14 lca's
Nistune
Plans
Fit all of the above parts once they arrive and give the car a good service. I then want to remove all the sound deadening and paint interior.
When I have all that sorted I would like to get some 50mm wings and overfenders, some sort of a kit, a full respray.
My main focus at the moment is on handling and performance and once I have the car setup properly I will look in to getting the car resprayed and if funds allow some nice jap dishu rims.
It is inevitable that my plans will change as I progress with the build though so nothing is set in stone as of yet
Thanks for looking I will keep the thread updated as often as I can
