well lads fitzy here again with yet more questions is a welded diff the best for driftin?:confused:
No. :afro:
It will explode and take the rear end of your car with it!
Do a search, this has been covered before
welded is the only job, I hate 2 ways, you always know what a welded diff will do.
a welded 2 way is far superior
Well, locked is locked
welded is a good job...never had a bother,
just get it welded properly and it'll be fine
Thought ye ment welded vs a 2way
Ha That's a new one tho a welded 2way, helical maybe?
id go 2 way had welded diff wuld not go bak to welded thats just me tho.
What are they like to live with on a daily ? Much understeer ? unpredictable ?
welded is a cunt in the wet specially if its ur 1st rwd, i was goin round a bend bout 60k in the wet and messin wit the radio for a sec and next ting the back of it was passin me out, i controlled it but i left marks and not on the road
chap i knew couple years back one of these buys a vtec and is colin macrea type lads seen drifting once and bought a georgous 180 i drove it one day and i said jaysus the welded diff must be a cunt everyday driving he said ahh its a kass 2 way got it welded for better rings........im not making this up either nearly puked, he cut in in half with an esb pole shortly after tho:cool:
LMAO.... jesus i nearly pissed myself there when i read that....lol
if a diff has been welded up properly with good hard facing wire and left to cool as slowly as possible, buried in a bucket of sand (atleast 24 hours) you'll break everything between the bonnet and the boot before you burst that diff.
its preference really..the only true way to find out is weld up an old diff stick it in and see what you think...
2way for me all the way
thanks for all the advice lads i,ll chance weldin up an old standard diff and see how i go..........:afro:
welded only way to go i removed a 2 way to fit a welded
diff there is allways the chance a lsd might open on you mid
transition and leave you on your lid as ive experienced first hand
