What oil and plugs are ye using on ye're sr20det's?
For use in a drift tramp and will be used maybe once a month for a dogging!!
Im usin ngk bcr8s plugs an mobil one oil forget the density but have the.container at home. think its 15. 50w or somethin.
they take something like 2.5 liters only
I asked plenty of people "in the know" for my first service and i'm using
ngk bcr8s
Millers race 10w 50
BCR8ES plugs @ £2 each
And either 10w60 or 15w50 motorsport oil
10w 60 castrol edge sport and bcpr7es plugs gapped to .7
NGK BKR8EIX plugs, and mobil 15w50 or 0w50
awh lads.ye have me confused again :(
ive a black top s14.which filter do i need?
going by what your saying stevo,a almera/permera will do??
:confused:
S14 S14a S15 use a different filter to the older 180sx/ps13 redtop/blacktop so yours is not a k11 micra filter if its the original vvt engine.. simple way to check the engines redtop/blacktop non vvt have straight rocker cover and s14 and s15 vvt are sloped towards the back(bulk head end)
From memory Blueprint filter part numbers are ps13/180sx non vvt redtop blacktop ADN 12110
S14/S14A/S15 vvt blacktops silvia and 200sx(s14) are Blueprint part number ADN 12112 which is same as sr20ve primera..
Really, thought they were the very same engine more or less :o
Ive one in the boot here, I'll go check...Quote:
Correct and right. ADN 12110. I Just stick with the one nissan gimme, for the sake of a pound or two at most.
@stevo Different oil pick ups,supposed to have different cams (I doubt it tho),kouki models use a different ecu compared to the redtop and non vvt blacktop,off hand that's what I think is different
a micra oil filter is the same, and most auto factos dont have 180sx listed as its a jap import
