Hi fellows. windows dont wont in the skyline and are stuck closed.
What sort of perspex is needed for the likes of perspex, is there any requirements?
also where and how much is it?
thank you please!!
thank you please!!
poly carbonate is nearly bullet proof but heavier as far as I know
Perspex and polycarbonate are similar in weight polycarbonate is shatter proof where Perspex isnt man factor is polycarb is expensive,get onto frankie he got a full set for his 2.2 180sx if my mind serves me right hope this helps
cool thanks lads. so would perspex still be ok? say 3mm?
3mm would be grand but be careful drilling it fragile as fuck,and cut as much as you can with a skilsaw,jigsaw with new blade for the corners ;)
i need to ask why you spending money on the car
One more thing blow torch the edges when ya have it cut to size leaves a glass finish nobody will know any different
id say 10mins wireing would sort it pewee the windows did work perfect in that car before gus got at it
because he cut the frames out of the doors theres feck all support for the weight of them so theyre starting to fall out of place now!
Would perspex not be brittle as in cracks easily,
Ive fitted window set before, was called "lexan" some place in the uk lazer cut it for the windows you want (got a full set for a evo 3) or you can get a sheet of it and cut it yourself.... its way more flexible as in you could nearly fold it back on itslef, just an opinion as i know perspex is cheap and cheerfull.....
@hunty whats the craic on them graphics????
Lexen make polycarb and yes Perspex is fragile but 3mm shouldn't be as brittle as 5mm or 10mm less weight ;) @ Paul have to pm me lad have no idea way graphics your lookin for ?
4mm polycarbonate is what you need... Do not put perspex in the car. Theres a crowd in ashbourne co. meath that sell sheets and they have a company attatched that will cut them out if need be. The only way to do it is... Cut with a jigsaw... normal blade for wood. Doesnt have to be the sharpest freshest blade in the world. Polycarbonate does not melt with heat when cutting like perspex / acrylic does... So makes cutting really easy... Just trace around the normal windows onto the sheet, cut it out and get a sharp blade of metal and scrape the edge and it will be perfect along the edge... No need for sanding... a scraper like a cabinet maker has is perfect... Use original rubbers tho, dont bond them in, it often looks cack...
Access plastics is the place is ashbourne. Sound to deal with...Just done a set for my polo at home..
Used perspex before and its junk!
Got a sheet of polycarbonate off murry motorsport, think it was €100 for a sheet that done my rear r32 window. excellent stuff to work with and very flexible!
If u wannt do it right pete get a window set off plastic4performance.....! Even has all the edges blackened so u won't see the sealer....! Looks dead tasty and will look good without using your rubbers again....!
But ur a misreable cunt so ul just do the exact opposite of what i say....!
Yeh haha that's right Robbie! Nah it's just I could get amount 8 sheets of it for the price of
The Murray motorsport stuff. But it's perspex!
Yea sure perpex is cheach because its shite....! You pay peanuts you get monkeys.... :)
You work for monkeys, you get peanuts!
eeeeeh, may i point out thet thers no window frames on the skyline..... so theyll just flop all round the place if ya use plastic
DONT use perspex man i wasted money getting a sheet for my back window on the 32 an it cracked in shite waste of time
