Gauging interest in my 180sx
Right seen what interest there is in my 180, its sat up since the portlaoise drift comp as ive no money to slide it :(
Ive kept it hopeing to get it out but the way things are going it wont see the light of day again this year or anytime in the near future its time to give this sliding lark up :mad:
Ive had it 7-8 months and its been driven twice so cant afford to have it sitting up doing nothing!
Will sell it complete for 3k and not a penny less, Dont bother throwing low ball offers lads as you will be nicely told to fuck right off!!
1993 registered 180sx
Kouki rear lights are gone!!! Rear bumper spats are gone!!!
Engine/Exhaust/running gear
Redtop SR20DET 70,000klms Engine complete with EVERYTHING includes turbo injectors coilpacks starter inlet ect ready to drop in real good healthy engine! €850
Perfect SR20 Gearbox €140
Unknown Aftermarket clutch €
4.3 Ratio welded diff with fresh castrol oil €250
6 Bolt half shafts €50
Prop €40
2 Piece catback €160
Brand new decat €50
Turbo elbow nearly new €60
Flexi Downpipe €85
Japspeed 50mm Alloy rad as new condition €125
Autobann88 Front mount €160
Justjap Engine damper €50
Oil pressure and boost gauge €80
Retop ECU and Engine loom €120
Suspension/Braking/Handling
GAB Front Coilovers HKS Rear Coilovers none leaking! €320
Justjap Full suspension Arm setup 3 rear arms front castor arm €265 used for one weekend!!!
Justjap Hydro with Yellow stuff pads and copper lines €135 again used for one weekend!!
Justjap Extra lock 4 stud Hubs and modified front subframe €
Standard Non hicas Rear subframe €60
Front and rear strut braces €50 each or €85 for both
Wheels 4x114
16x8 ET10 Rota Grid Drifts in white with Brand new Uniroyal Rainsport 2 rubber on fronts fecked rear tyres €420
16x7 ET42 Rota Grids (not drifts) With 4-5mm tyres only 3 wheels €120
VRT'D Shell with logbook
Shell with all glass front and rear lights bonnet wings boot doors interior dash fuel tank brake lines master cylinders logbook ect €650
All other bits are there just ask if you need them!
Build thread/pics here >>>>>>>> http://www.driftireland.com/forum/sh...ad.php?t=11794 <<<<<<<<<<
