CS-Autos S15 Mark Synnott
here is a quick rundown of the new panic project! the car has been sitting here for a while now but we only stared into it yesterday, and it has to be out for prodrift round 2 in fermoy on 3 weeks time!!!
so quick spec on the car when we got it:
01 specR s15 shell
s14 engine and 5 speed box
full interior
full body kit
+30mm vented wings
+30mm over fenders
full stock suspension
some crappy tail lamps
and bits waiting to go on:
temparay 6point bolt in cage,
red top sr20det tdp pullys, mhg, nismo 550cc's, je pistons, acl bearings
z32 afm
Apexi power fc
full 3" exhaust system
full trust td06 20g turbo kit
big trust fmic
alloy rad
orc twin plate clutch
rb25 box
omori oil temp, oil pressure, water temp gauges and apexi rsm, built into dash cluster
gtr pump
custom loom
pair of seats and harnesses
sparco dished wheel
hydro
skyline brakes all round
project MU braided brake lines all round
hsd cs2 coilovers
cusco rear camber arms
cusco rear toe arms
driftworks rear traction arms
custom CS-Autos front steering lock
driftworks front lower wishbones
cusco tension rods
when we first got the car we pulled the engine and box and sold them, then the interior came out most of this is still here if anyone need bits???? sound deadining out came out last month then it sat there, then yesterday it came in for some real work, fired in a bolt in cage for a test fit and to cut the dash so we can paint the inside of the car and the cage and not worry about marking them when fitting the dash at at later date,
PICS:
http://i581.photobucket.com/albums/s...3/DSCF9641.jpg
http://i581.photobucket.com/albums/s...3/DSCF9642.jpg
http://i581.photobucket.com/albums/s...3/DSCF9634.jpg
http://i581.photobucket.com/albums/s...3/DSCF9635.jpg
firstup were the rear arches dan moorhead had done a very nice job flairing them out the the overfenders before but it was just going to be a roadcar then so i did a bit of a job on them, will allow lots of lowness and decent wheel to over fender gap,
i forgot to take a pic of the drivers side before i did it but here is the passo,
http://i581.photobucket.com/albums/s...3/DSCF9644.jpg
http://i581.photobucket.com/albums/s...3/DSCF9645.jpg
http://i581.photobucket.com/albums/s...3/DSCF9646.jpg
http://i581.photobucket.com/albums/s...3/DSCF9647.jpg
http://i581.photobucket.com/albums/s...3/DSCF9648.jpg
http://i581.photobucket.com/albums/s...3/DSCF9649.jpg
tunnel cut out to make more room for removeing and fitting the rb25box
http://i581.photobucket.com/albums/s...3/DSCF9636.jpg
then the boot floor came out!!
http://i581.photobucket.com/albums/s...3/DSCF9643.jpg
http://i581.photobucket.com/albums/s...3/DSCF9654.jpg
http://i581.photobucket.com/albums/s...3/DSCF9653.jpg
it will be left as above, and will be fire/smoke walled at the rear parcel shelf/ rear seat back,
http://i581.photobucket.com/albums/s...3/DSCF9652.jpg
then moved on to the front, the battery died in the camera after this pic move to come soon
