lads deos any know if everytin will fit back together ok if put s14 rear subframe onto r32 as in hubs etc...dont tink shud b prob but nice to get second opinions
Cheers
Cheers
The s14 subframe is wider... So you'd need to get off centre subframe bushes
s13/180sx bolts straight on and will remove hicas if its the right subframe!! if ur using r32 hubs all you need is to take out the balljoint and replace the bit on the hub with a polybush from driftworks or sumat!
and i have one there with all arms & locking collars too as it happens :D :D pm if interested!
you mean the full pro handling package?if so then they do come with bushes in the pack so id say u will be grand,
to be sure just give them a bell and they will tell u straight away on the phone if u tell them what your doing, or alternatively if you go onto the shop website they have a new chat feature to speak to customer service straight away!
i dont know the answer to this myself but if you are swapping to a S14 subframe would it not affect your coilover choice as S13/180sx/R32 Rear coilovers are all the same but if S14/15/R33 Rear coilovers are the same but arent interchangable with the 13/r32 ones . .
ya if your using the R32 hubs you should be fine so! any reason your using the s14 instead of s13?
is there advantages to it?
will the coilovers fit? as s14 coilovers are way longer! like would u need ta use s14 coilovers
No lads the coilover bolts into the hub so they will be the same.....! There is other advantages other than a wider track with but i don't wanna be up all night....!
