As above need a new master cylinder for my 180sx as my old one is wanked. I have 4 pots from an s14 and was wondering is there a difference between the s13 and the s14 brake master cylinders. If so will the s14 one fit the s13?
Thanks
Thanks
have you abs? think non abs ave 3 outlets.abs ave 2. have you skyline 2pot calipers on the rear as well?
[QUOTE=johnbro;251378]Yes if you have braided lines or want to bend hardpipes
Is the s14 master cylinder better?
the s14 might be slightly bigger cyclinder but direct bolt on so it is
if your worried about having better breaks try get a skyline one 32 or 33
should do not a 100% do but should be the same
Iv one off an r33 here if It's any good to ya
Pm'd...........
You gonna use proper one and should be same as originally equipped with the car you took the brakes from to retain breaking balance otherwise the back would overtake you during braking.
Btw, I've got R33 non abs one and s14 silvia (tbc if abs or not). I'll be in Cork next week
