New S2000 Drift Car Build!
Right about time I got this thread up, I bought this S2000 a little while back with some rear damage and with no engine, box or loom. Meself and John (the bro) decided that this was the car to build into a proper fast drift car even tho the setup could take a while, and it will be different:D
So the plans for the car at the min are.....
Forged F20c with linered block for the boost
Full-race exhaust manifold depending on funds
In around Gt30/35r size blower with custom housings
E46 M3 6 speed box
GTR Skyline rear diff and custom shafts
Suspension I haven't decided on yet
MoTeC M84 ECU with launch controll, anti lag, lambda controll
Pedal box
Full custom TDP T45 roll cage
Evo 7 Brembo 4pot front Brembo 2pot rear with custom TDP bells and disc's
Parts I have aquired,,,,,,
F20c engine:D
GTR diff and shafts
Brembo front calipers
Pedal box,,,,,
That is the basic outline of the setup but the main difference of this build is the time I am spending on the chassis, every un-necessary kg is coming out of the car as you will see from the pics:D
Anyway I will explain everything in detail as I get through the build,
http://i286.photobucket.com/albums/l...g/103_1312.jpg
The car had to go to the body shop first because the back chassis needed a little pull:eek:
http://i286.photobucket.com/albums/l...g/103_1311.jpg
And this is how it came back,,,, The stripping started,,
http://i286.photobucket.com/albums/l...g/103_1314.jpg
http://i286.photobucket.com/albums/l...g/103_1315.jpg
http://i286.photobucket.com/albums/l...g/103_1316.jpg
All the basic stripping done,
http://i286.photobucket.com/albums/l...g/103_1325.jpg
Front subframe out,
http://i286.photobucket.com/albums/l...g/103_1326.jpg
Rear subframe out,
This is where the weight saving starts:cool: There is alot of excess chassis bracing in the S2000 due to having no roof, so all of it has to go:) The new cage will do all the bracings job and better,,, and away we go on the spot welds:mad:
http://i286.photobucket.com/albums/l...g/103_1327.jpg
http://i286.photobucket.com/albums/l...g/103_1328.jpg
http://i286.photobucket.com/albums/l...g/103_1329.jpg
Alot of the underneath strenghtning can go too,
http://i286.photobucket.com/albums/l...g/103_1330.jpg
Time to get the sills off, a whole lot of not nice heavy side impact protection in behind them that needs to go,
http://i286.photobucket.com/albums/l...g/103_1332.jpg
http://i286.photobucket.com/albums/l...g/103_1333.jpg
After a whole shit load of spot welds, finally got one side done and set into the other side,
http://i286.photobucket.com/albums/l...g/103_1334.jpg
Thats all the pics for this week will have more at the weekend I hope, it takes so much time removing chassis parts because of the spot welds il keep you all updated as much as possible!
