Os giken super single problem??
Iv fitted an os giken super single clutch to my sr20 180sx. I got a release bearing with the clutch and it looks to be the right one, but im not sure.
The car wont go into gear when its turned on..it will when its turned off, it seems as if the clutch isnt disengageing.
We took down the box again and put a spacer on the sleve behind the release bearing, put the box up and still the same problem??
We even tried putting a spacer between the rod of the slave cylinder and the fork after, and it still only pushes the fork in the same amount, as in the rod didnt come ouit as much with the spacer.
The slave cylinder is a brand new nismo aswel, so its defenetly able to push it.
Any help appreciated and sorry for the essay:)
