Long shot i know but recently bought 15mm bolt on spacers and the nuts i got with them are too long and stick out about 3-4mm from the spacer so looking for ones that sit flush with the spacer
lorcan at drift2 has em i think
Na he doesnt already asked him
drift works
All they have is these and they look to be the same as the ones i already have
http://www.driftworks.com/shop/wheel...issan-etc.html
can ya not just trim a bit of the end of them with a grinder?
I could but I'd prefer not to go down that route there's something about cutting my wheel nuts in half that makes mr nervous haha
true but i don't think ya can get much shorter ones than driftworks ones off the shelf.If ya dont want to cut the nuts only other option is drill the spacer holes a bit deeper and let them sit in further
True but iv seen shorter ones before but can't find where there sold, spacer holes are kinda as deep as they could be not much room in a 15mm bolt on
get a 5mm slip over spacer if u hve room at ur arch
Na dude standard archs :(
i had to put 2 5mm spacers inside mine too
5mm spacer isn't goin to make the nuts any smaller though
no but if ya put 5mm spacer inside the bolt on spacer your loosing 5mm that the nut has to thread onto
Ya I know that but that's not my problem it's the nuts being too long, studs make no difference as I'll be cutting them anyway
One solution would be . to buy set of 25mm and swap the nuts with yours the 25 should be deep enough to take the ones you have then sell them on afterwards
Ya that's crosses my mind alright said I'd chance my arm at finding the nuts first though
If for example your nuts are 50mm long and are sticking out too far and you want 40mm nuts that will be flush, you may as well just cut your own ones cause either way the cut one will have the same amount of thread as the new ones you want to buy......... making sense to ya Stevie boy lol
no.............
....................... did u sort this yet
Not yet Dude
icetronx have them in stock , I only got a set a coupla weeks ago, they have two kinds for bolt on spacers and one kind is Very slim and they are 2e a nut.
Where are they based?
Rathcoole .......... https://www.icetronix.com/index.aspx?page=misc&id=9
I'm sure they can sort delivery
Link just leads to a blank page?
Was on the page they dont seem to have what i want?
Any pics of the ones you got dude? no hassle if ya dont
no sorry not at the moment.
