As above really anyone got one of these knocking around at a bargain basement price??
PM me asap!!
PM me asap!!
ae111's dont have an afm
intake air temp sensor i'd say, whats the problem with the car
ya intake temp sensor
Rough idling like a mother fucker nearly cutting out, Drinking petrol from over fuelling as the plugs are new but now black as fuck and the engine light is on!
Cant read the code off the diagnostic comp, says Toyota restricted code and toyota wont tell me what it means, so either I try the intake temp sensor or go Toyota and let them rape my brother!!
its mot the intake air temp sensor anyway
what number code is it flashing?
id sat its the lambda sensor by that discription common to go on them and they over fuel like cunts then and flood when ticking over for any length of time
I had a similar problem before it was more intermittent tho turned out to be a faulty knock sensor causing the ignition to advance and retard, I was able to read fault codes with my scanner and was showing up the knocks sensor signal
@ Mark,Do you buy from Celtic CP?
Yeah get a good bit of stuff off them
Thought it might have been the Same MarkAndrews alright.
Was in there last week and heard your name mentioned for delivery.
Sorry for offtopic OP!
Seem nice guys! I met Alan and a short roundish guy in a Snickers jacket!
under the bonnet their should be a diangnostic connecter, i think its, t, and te1, cross them with a split pin, count the flashes off the engine light, for example 2 slow flash's followed by 1 fast flash is 21. google the number you get and you should get your fault code, or fire it up here, i no a few of the common ones.
u dont need a diagnotic comp, the ecu does all the work for you
what number(s) is it flashing
