Have a hks fcd here i bought it from Pete but never fitted it to my car €60 or nearest takes it..:cool:
fit it and wind up your boost woo woo woo
Whats it do?
Defends the Fuel From Cutting hahahahaha
Stops the standard fuel cut of point.
I actually need one of those.... whats involved in fitting?
3 wires into 3 of the ports in the ecu...
is this a fuel pump??
The HKS FCD is an electronic device developed to properly raise the factory fuel cut level on factory turbocharged vehicles. As modifications are made to optimize engine performance, the factory fuel cut is often triggered by higher boost levels which activate a fuel delivery cut-off as a failsafe procedure. Symptoms of fuel cut are hesitation, bogging, and/or illumination of diagnostic indicators.
Anyone know when the the boost cut cuts in on an r33? Might need this.
Cheers! my car cuts out wen driftin in 3rd it feels like the fuel
is getting cut.. so is it one of these wat i would need??
when you rev the car out ie. bouncing it off the limiter thats the fuel being cut. would you be at full mahooofussss revs in third gear while mid drift??? if so this could be the answer. but it will cut again but just not as early. your engine wont thank you for it.
that could be it dude, on my s13 it didnt cut on full boost in 1st or second, but in 3rd as theboost had built and i was picking up speed it cut like a cunt and felt like slamming on the brakes!
feels like it runs out of fuel or something, but then you let off, and can floor it again until its fully boosting and under load?
they are a gud jod,,
heres a wireing diagrame lads
http://www.xspeed.com.au/manuals/fcd_install.pdf
humpty bumpty:p
50 yoyos posted? I could send you a postal order?
Pm sent there lad.
Held for Newsome:)
It will be alll mine at japfest. Then its up with the boost on the glanza.:D
