well want to try tidy up the engine bay in my s14 a bit..so whats not needed that i can take out can any1 tell me??
BUMP any1 :(:(
take engine out hve laoads of room then will look nice and tidy :D
nAh wat kinda car is it?
S14.....said it in his original post....http://www.specsavers.ie/
air con ,charcole cannister,
im in the process of doing this at the min, have stripped everything out of the bay, meaning all wiring, fuses, battery, expansion tank, etc etc
basically all i will be left with is the engine, brake master and clutch master, and wiper motor, ive sealed up all holes in bulk head and am now at the stage of rewiring. for that im basically putting all looms and fuse boxes inside the car behind the dash and then just running the wires for the lights and fan up under the front wings so its all hidden, then running the wires to the engine from a new hole i made beside the clutch peddle and heater box, wires come out at intake side behind the manafold so again all hidden
i have just havent had the time to put anything together for up loading, il prob put up a project topic when its finished showing the different stages
its supprising how much stuff is actually in the bay that doesnt need to be
to make life easy its def worth taking out the dash to do it btw
