Is my master cylinder f**ked????
Right story is, changed the rear calipers removed abs and ran new lines around.. Started bleeding while the car was off wasn't getting anything kept going still nuttin pedal just go to the floor, was getting a bit of pressure while pumping and it held so wasn't a leak in the system but when i let off and go again it would go straight to the floor kept kept going and was sure it was getting good, so i started the car and the pedel nearly went to the floor itself it was so so soft when i pressed it so while car was running i bled it an foot still going to the floor, when i pump the pedal really quick for a while the hydro gets tight and when i pull it the hydro keeps its pressure but the pedal goes to the floor after taking foot off. I have bled enough was doing it the last 3 nights..
Thanks for reading any help appricated.
