Just a standard engine, turbo, injectors but with an FMIC, Alloy Rad and A/M ECU ? I'd be happy with 300bhp but is that too much to ask ? Little or no experience with these engines so any help appreciated.
300's not a problem you could push from 36-400 but a metal h/g would be advidsed...!
one of the lads here was pushin 328bhp on a what you have listed.....
standard head gasket went after a few hard days in mondello tho.
300 -350 that what mine be running at,
few bit done to her, but next step metal head gasket do
worth it
Cheers Robbie mate, where would I get the metal headgasket ? RHDJapan ? Car will be getting a good going over in October...
Cheers drift student...
Thanks johno
Dave at jap performance stocks them...! On a good healthy engine 400 bhp could be ran with 1....!
Frsport.com
I got everything off them cheap and good
delivery service.
Ive a metal headgasket there Bren, brand new HKS item will sell it cheap to clear.
im boostin 1.4bar on a cometic 1.2mm steel h/g
got it from rm performance in killarney. forget how much tho..
ive seen a few sr engines running over 400 brake stanard wit bolt on bits and mapping
Will do lad...
Thanks Robbie, have dealt with Dave before ;)
Cheers Davie
How much dude, pm me and the thickness
Cheers man, 1.4 not a bit much ? Sorry used to dealing with n/a's and rotaries
Sound Bart ;)
She'll be getting thrashed at the ring mate so I think 400bhp would definitely pop the engine :(
ive ran 430 out of a stock sr20 block!!!!only mods wer 740cc injectors,hks cams,hks 3037 turbo kit!!!gtr pump this set up ran for 2 years and another year on a td06!!
Wow that is savage Dan, who mapped it for you ?
tdp map will get over 380-390 on a stock engine with bolt on mods with just a metal head gasket well over 4-450 safely!! and fire in a set of pistons and race bearings ur talking 500 on stock rods and crank no problem!!
Lmao ^^^^^
i am running .85bar on a standard 180sx engine with just a front mount and stainless exhaust hks actuator and nistune ecu that was road mapped and i got 244bhp on a dyno dynamics dyno and that is with the cat installed.so that will give you a ball park figure of what to expect out of a standard engine i could get more out of mine if it was dyno tuned and running 1bar or more but i want reliability.Also getting 30-35 mpg with combined driving if i drove like a granny i could probably get more.
One thing tho your standard injectors would they be good enough to get you to 300bhp??
I keep all cometic steel gaskets in stock along with all rebuild parts...
I Have run standard SRs @400hp...
