Want to know what the RIGHT way to bleed the brakes in a car with hydro h.brake, people have different ways of doing it.
Do you start from the front and then bleed the rears with the handbrake pulled back and just use the brake pedal to actually bleed the fluid.
I saw a lad bleedin Colfers rears and he wasnt touching the handbrake at all??
If you do it that way will you have good pressure in the handbrake when finished?
Ive all the fluid out of my car at the moment and in the next couple of days ill be filing the system, what fluid is best to use Castrol response or that mintex stuff?
