down to no time to spend on the car and space needed in the drive have to sell my R32
'91 regd shell, NCT 05/2014 some sort of stock front bumper, type m skirts, some funky spats that i never came around to remove, body is solid bar rear arches but theyre not the worst or just quarters on it for fat look would sort it easily, front bumper and skirts sprayed from rattle can and bonnet is grey, have a carbon gtr type bonnet needing repair and gtr grill to go with the car, gtr headlights already on it.
full type m interior including 5 piece skyline mat set, all dash vents not broken and in place, apexi boost gauge, tomei AFR gauge, apexi S-AFC, apexi turbo timer, autopage remote start alarm, custom kill/start switch.
spec1 rb25det internally stock with new timing belt and water pump (proper hybrid loom from rb20 and rb25 looms to get everything working as stock, its plug and play to r32 chassis), new plugs, BB AET hybrid turbo (equivalent to gt2871r) with all braided lines on stock exhaust mani, new head/manifold gasket, metal mani/turbo and turbo/downpipe gaskets, japspeed 3.5" elbow+downpipe, 3.5" stainless kakimoto exhaust, apexi air intake on custom hard pipe, hks recirculating BOV, large front mount with 3" piping, large aluminum rad, oil catch can, exedy 3 puck clutch, rb20det gearbox with new oil, 4.1 nismo 2way diff 5bolt non abs with new castrol b373 oil in it.
fully adj Tein coilovers front, height adj Tein coilovers rear, gtr strut brace front and some jap strutbrace rear,
front: r33 front LCA's, r33 steering rack on pollybush bushes, adj camber arms, new track rod ends, spacers in steering rack for more lock, new pollybushed droplinks, adj and offset traction arms, r33 calipers and discs with new pads
rear: r32 gtr brakes, new pads, r33 nismo LCA's, adj camber/traction/toe arms, pollybushed droplinks, pollybush antirollbar bushes.
suspension geometry was set by Jay Rockett castor and camber settings are bang on with 3deg negative camber all around and 17deg castor, tracking is a bit off tho.
now bad points: tracking- not the worst but needs redone, ICV needs cleaning out, rocker cover gasket could do with change, actuator on turbo is a bit wanky but works, with this turbo AFM maxes out at 4500-5000rpm, so z32 AFM and nistune and that would be end of engine to do list (have apexi PFC for rb25det here as well for few extra bob)
handbrake shoes need replacing, and theres a wheel shake when braking or at 65-80mph, cant be brakes as changed them to r33 ones and still here, might be down to front bearing need tightening or smth stupid that i overlooked, but thats about it, just have no time what so ever to spend on it and wont have it till spring... so if it goes somewhere to be finished would be awsome! just dont want to brake it as ive put it together from empty shell...
heres few pics anyhows:
http://i521.photobucket.com/albums/w...psc887eb3b.jpg
http://i521.photobucket.com/albums/w...psf0319e68.jpg
http://i521.photobucket.com/albums/w...ps6c6c003b.jpg
http://i521.photobucket.com/albums/w...psc659ad3e.jpg
http://i521.photobucket.com/albums/w...ps25753015.jpg
http://i521.photobucket.com/albums/w...ps8f4bdd3e.jpg
http://i521.photobucket.com/albums/w...psb488abaa.jpg
http://i521.photobucket.com/albums/w...ps81d98cd9.jpg
price wise- will ask for €4500 on staggered set of work modenas 17x9 et16 17x10 et22 (same wheels as on the front of the car in the pics) or €4200 with bring your own wheels option, not insulting offers always welcome, car is in wicklow and i'm best reached on 085 7796399
thanks Tomas
