TRIAL demo R32 skyline
I bought this car about a year and a half ago and ive about 5-10,000kms done with it.
Havent driven it since january bar going up to the garage about a month ago to get serviced, new front tyres (advan a046's) and paint the front bumper.
I dont have the time or money to drive the car so im putting it up for sale.
The car was owned and imported by Chris Gray from the north, he works for Trial japan as a european sales rep or something...
The car has no tax since the start of the year and has never gone in for an nct, when i used to drive it you'd get away with it so i never saw need. The only thing i feel it needs for an nct is rear brake shoes i have the discs off and they are worn and the handbrake is weak as a result.
Im going to copy and paste Chris's spec list of the car, i also have a folder from Trail with proof of build/ownership etc..
Im also using pics chris took but if someone wishes i can take new ones but the car looks the same :)
93D is the reg of the car. All ive added is a beeR rev limiter which i only used once because i was told they were bold after fitting it! And serviced the shit out of it :)
Spec:
> > > > >ENGINE & MANAGEMENT & COOLING & BRAKE:
> > > > >TRIAL RB 2.4 SPEC
> > > > >TOMEI FORGED PISTON KIT/RING
> > > > >NISMO TIMIMG BELT
> > > > >HKS RACING PLUGS/LEADS
> > > > >AIR COND COMPRESSOR ASSY
> > > > >NISMO INJECTORS
> > > > >BIG CAPACITY AIR FLOW/M
> > > > >HKS GT2530 TURBINE KIT
> > > > >REINFORCE ACTUATOR
> > > > >EXTENSION KIT
> > > > >HKS OIL COOLER
> > > > >APEXi INTER COOLER SRS
> > > > >ROM TRIAL TUNED CPU
> > > > >FRONT PIPE
> > > > >CATALYST ADAPTOR
> > > > >240 L/H FUEL PUMP
> > > > >HKS BOOST EVC3
> > > > >HKS SQV
> > > > >APEXi SUPER CATALYST
> > > > >ENGINE DOWN
> > > > >POLISH TO VALVE
> > > > >SIM ADJUSTMENT
> > > > >VALVE TIMING ADJUSTMENT
> > > > >CYLINDER BORING
> > > > >CYLINDER HORNING
> > > > >POLISH TO CYLINDER BLOCK
> > > > >POLISH TO CYLINDER HEAD
> > > > >ADJUSTMENT TO METAL
> > > > >TOMEI 82mm PISTON KIT
> > > > >HKS METAL HEAD GASKET
> > > > >HKS CAMSHAFT IN&EX (264Deg)
> > > > >HKS CAM PULLEY KIT
> > > > >BLITZ RACING RADIATOR/CAP
> > > > >NISMO REIN-FORCE ENGINE MOUNT
> > > > >NISMO REIN-FORCE MISSION MOUNT.
> > > > >SPOT WELD BODY
> > > > >N1 WATER PUMP
> > > > >NISSAN OIL PUMP
> > > > >ORC TWIN PLATE CLUTCH ORC-709-01N
> > > > >HKS EIDS (TYPE-H1) IDLE
> > > > >GEAR BOX ASSY
> > > > >TOP FUEL SUPER RELEASE FORK
> > > > >OHMORI OIL PRESSURE METER
> > > > >OHMORI OIL TEMP METER
> > > > >OHMORI WATER TEMP METER
> > > > >JOINT ADPTOR
> > > > >2 ALPINE REAR SPEAKER
> > > > >OS GIKEN SUPER LOCK LSD SPL TYPE
> > > > >EARTHING KIT
> > > > >HKS POWER FLOW
> > > > >SARD CATCH TANK
> > > > >BLITZ UPPER HOSE
> > > > >APP BRAKE HOSE
> > > > >HKS COILOVER SUSPENSION KIT
> > > > >NISMO ARM TRANBARS LINK
> > > > >NISMO ARM FRONT UPPER LINK
> > > > >NISMO ARM REAR A ARM
> > > > >NISMO ARM REAR UPPER LINK (FRONT)
> > > > >NISMO ARM REAR UPPER LINK (REAR)
> > > > >CUSCO PIRO TENSION ROD
> > > > >CUSCO HICAS LOCK CYLINDER
> > > > >CUSCO STABILIZER
> > > > >BREMBO BRAKE SYSTEM F40
> > > > >QUANTUM RS STREET F/10K R/8K
> > > > >CUSCO CARBON TOWER BAR
> > > > >BREMBO BRAKE ROTOR 340mm
> > > > >BREMBO BRAKE SYSTEM REAR
> > > > >CLUTCH MASTER CYLINDER
> > > > >TRIAL BAZOOKA MUFFLER
> > > > >RACING WHEEL/SHIFTER
> > > > >RECARO INTERIORS
> > > > > FULL TRIAL AERO KIT
> > > > >17” WORK EMOTION CR KAI WHEEL
> > > > >YOKOHAMA ADVAN NEOVA TIRE
> > > > >HID HEADLIGHT
http://i741.photobucket.com/albums/xx58/frankae86/p.jpg
http://i741.photobucket.com/albums/xx58/frankae86/o.jpg
http://i741.photobucket.com/albums/xx58/frankae86/n.jpg
Price on the car is 8,250euro
I may take p/ex cash my way or swap for a VERY good ae86 like blaines :p
Frank 086 3234223
Quote:
Originally Posted by
ps13
unreal...i want
Thats what i said too ;)
thats tidy yoke frank, u shud av no bother sellin it... sum spec..
Cheers lad, i need another ae86 its months since ive had one :(
wow! what brake she pushing?
savage car good luck with the sale , i see my 3 spokes didnt make there way onto it:D
best of luck with the sale..i had a ps13 built by trial a few years ago...engine
was as strong as hell still going strong...they build engines to the best quailty..
sweet car man savage spec, i remember seein that car for sale a while back
went to buy this car before i bought my own scary quick car ,didnt buy due to a bit of cancer on it ! Other than dat seemed ok besta luck bud
