right im looking for an r33 front right hand camber arm must have a good balljoint and bushes in it neaded for the nct, any 1 have 1?
Yup have camber arms there, you sure it's the camber arm bushing though? Mine was the control arm bushing.. Being the outer bush which isn't part of the camber arm??
Anyways... There if ya want it... Say €25 and whatever the postage is??
control arm bushing, thats what its called!!! yup, its that bush thats needed... exact bush thats pictured up on this thread, something like the 7th or 8th comment??? http://www.skylineowners.com/forum/s...d.php?t=133956
have one also
Then u need the bushing, they ain't part of the camber arms at all, and nissan don't do them separate from the arm,
Concept do poly bushings to replace them, was all I could find at the time. Careful getting second hand oem ones as they can be a Cnut to get out in one piece. Flat head screw driver and a hammer and tap around the lip does it though.... Eventually.
Think they are 70/80 sterling,
I have a complete arm including a perfect bush :D
Easier to replace the whole arm "3bolts"rather than messing with bushes.
