fairly taking shape now man. maybe keep the plenum and cut it a bit at the trottle body end.
Happy Christmas,,,
Few little updates.
350z box finally returned with sr bellhousing and slave cylinder. Mount fabbed up. Seriously happy with the tunnel in these rx's plenty room for this big lump of a box.
next up mount rad, IC and oil cooler
http://i36.photobucket.com/albums/e5...psbmogqbot.jpg
http://i36.photobucket.com/albums/e5...psbxxta2zz.jpg
http://i36.photobucket.com/albums/e5...ps6b12720a.jpg
http://i36.photobucket.com/albums/e5...psf4981023.jpg
Sick build mate :)
cheers dude, I'll be up for that s14 plenum someday :)
HSD coilovers in, testing the steering lock today with standard arms, The size and location of the calipers makes achieving a good angle impossible with the standard setup. As well as that the Caster angle and hub, with the standard arms on full lock there's serious positive camber on the side turned out. So I'm attempting to fabricate my own arms. If all goes to plan I should have Caster and Camber adjustment.
http://i36.photobucket.com/albums/e5...ps060123b4.jpg
Here's the simple gig that will mock up the new Rose jointed arms. The one gig will make both sides as they will be a simple mirror image of one another. Both arms will be near 3" longer
http://i36.photobucket.com/albums/e5...ps7de50f21.jpg
Going to offset the ball joint pick up point to reduce some of the caster angle. Will do this below as well.
http://i36.photobucket.com/albums/e5...ps59a11f86.jpg
Top arms should be pretty easy, its the bottom ones I'm worried about
Wish wisefab had a kit for this
Turned this teak knob
http://i36.photobucket.com/albums/e5...psporqaudh.jpg
Gone mad...this is in the post!
http://i36.photobucket.com/albums/e5...psef8k7wti.jpg
Should be epic !!!
oh god.....looking forward to this being finished even more. that aerokit is epic loking.
can the front splitter and cannards be bought off them seperatly? id like them for my fd3
Control panel nearly sorted now
http://i36.photobucket.com/albums/e5...psm9sunpd9.jpg
http://i36.photobucket.com/albums/e5...psjn78b0v1.jpg
