whats the story with the rx7
the story is she's going on the track verry soooooon!!!! :cry:
she would be out in tynagh on the 24th only no 1 seems 2 have plugs or a clutch master cylinder in stock...
plugs!!!! come on a f**king lawn more or some thing has 2 have the same plug!!!!
http://s3.postimg.org/6mladlmtr/IMG_0556.jpg
http://s9.postimg.org/i4j09wjqj/IMG_0568.jpg
http://s22.postimg.org/ole7a02fx/IMG_0598.jpg
ok well i think this is well due an up date
only some boxes ticked so here it is...
spec so far
sr20det red top
port & polish head
tomei rocker stoppers
BC 264 CAMS
BC spring set & caps
BC valves
cosworth 1.1 GASKET
CP 87m Pistons
arc baffeled sump
ACL Bearings
ARP bolts used every where
OEM Seal kit
s15 turbo ( for now )
braded lines
7 layr gasket
blitz nur spec turbo back exhaust
Std Fly Wheel & ARP Bolts
C/C COMP CLUCK STAGE 5 sprung
Nismo GTpro2 way diff
30mm 6 Bolt Shafts (thicker)
electric power steering set up (hydrolic damper adjustable)
solid bush
spaced rack
apexi n1 coilovers front & back
apexi camber plates
fully polly bushed all round
TDP subframe bushes
WHITE LINE rollbars front & back ( need bushes as standard wont fit???)
cusco camber arms
cusco toe arms
cusco brace front & back
finger well and truly out!!!
well i had fully parked this project after geting a
ae86 & an r6 just was having 2 much fun to bother
but over the x-mas after finding a box of bits
i forgot i bought i decided to tackle this thing...
everything is still the same except i got a greddy t518z apexi power fc d-jetro
some defi goodies and a rocketbunny kit..
pics to follow...
