, the rocker cover was getting a bit grubby so decided to re-spray it....
This is it off, as you can see its seen better days!!!
http://i288.photobucket.com/albums/l...onepics011.jpg
http://i288.photobucket.com/albums/l...onepics012.jpg
Next i got the grinder out and took off the nissan bit and other bit of writing, smoothed it all down, gave it a good clean and sanding to smooth it all out ready for paint
http://i288.photobucket.com/albums/l...onepics013.jpg
so next up was 3-4 coats of high temperature primer, and then a few coats of blue
http://i288.photobucket.com/albums/l...onepics014.jpg
http://i288.photobucket.com/albums/l...onepics015.jpg
i masked it all up then , and covered the bigger bits with newspaper
http://i288.photobucket.com/albums/l...onepics016.jpg
http://i288.photobucket.com/albums/l...onepics017.jpg
next sprayed these areas with white paint and then removed all the masking tape/paper and gave it 3 caots of petrol & oil resistant lacquer
And the un fitted finished rocker cover...
http://i288.photobucket.com/albums/l...onepics020.jpg
and fitted
http://i288.photobucket.com/albums/l...ld/rocker2.jpg
http://i288.photobucket.com/albums/l...ld/rocker3.jpg
