Sweet dude, Should be good for some pics then soon ay
@bnollie ah ill only have to change if i want firm pedal...wont mind if its only small bit spongey.
@matt oh ya def be ready for some pics soon goin thrownin everythin onto car monday an goin beatin the arches out a bit wen iv the front hubs off for more low:D
update today...my sledge hammer met my front arches today an made loads room for my wheels an more low:D jus have to extend the wirin loom on the driver arch to clear the wheels....bads points are i need a track road end cos one mines fooked an need a rubber boot for the steerin rack cos one mine has a tear in it.
anyway got a package in the post today an it was my godspeed tension rods
http://i699.photobucket.com/albums/v...9082010594.jpg
and i fitted my s14 front hubs an skyline brakes
http://i699.photobucket.com/albums/v...9082010593.jpg
an fitted the tension rods too
http://i699.photobucket.com/albums/v...9082010595.jpg
bad thing is now i need the skyline master cylinder cos the s13 one cant build up enuf pressure wen the engines runnin to give me a firm pedal
Jesus never heard of that problem before....!
the s13 cylinder should be fine man, im using a standard 180 m/s with r33 brakes all around
heard of it happenin few times...the brakes work like its just the pedal is very soft
my one was workin fine till i put the liner front brakes on...so master cylinder should be fine an wasnt let run low so no air in the system after i bled it
You sure its bled 100% sometimes there a bastard....!
