head is wrecked lookin at this yoke..:mad::mad:
any one want a job to get this yoke up and driving???
bump.......
Don't know if this helps but I had that exact same problem with my 180.
It was turning over and not starting
I had the battery hooked up to a van:D, took off fuel line plenty of fuel being pumped in, kept turning and turning but wouldn't fire:confused:
The problem for me lead back to me messing with the wiring loom.
I accidentally brushed off some sensor?? don't know what it was for, it looked OK from distance, only when I reached down it was a bit loose (bad connection)
Then I turned and she fired up first turn:cool:
Image below shows roughly where plug is
It's worth double checking all plugs and sensors;)
bump........
im in the same trouble help please......power going to coils but no earth pulse,so no spark ,starter signal wire not working either so giving it power manually ????????????????????????????????want to do mondello next week help us please sos sos sos
might be a stupid question but did you change the spark plugs? new ones might help?
